Mat foundation (22ft x 16 ft)
I have to design a mat foundation (22ft x 16ft). Due to some environmental issues the maximum thickness of the foundation is limited to 30 in. Here are the details.
fc = 3ksi. I have used PCA mat to design the foundation. The thickness seems to be OK for flexure, punching shear and I am getting good results. The only problem where the punching shear is not satisfied is at one of the circular columns (Dia = 2ft). Here are the punching shear check details.
vu = 199 psi and vc = 164 psi.
vu - factored shear stress at the critical section
vc - factored shear resistance of concrete (without considering shear reinforcement)
Is there any solution for this problem. Can the bars provided for flexure reinforcement account for any shear resistance. Or can I provide any extra shear reinforcement to get this 30 inch mat work. Any suggestions regarding this will be greatly appreciated.
RE: Mat foundation (22ft x 16 ft)
DaveAtkins
You can add shear reinforcement if you need using the ACI, but do not count the flexural reinforcement. It doesn't work that way. You can also build a base around the column to increase b0 to a suitable length, or use a stronger concrete f'c. Though you said you need 30 inches max, perhaps you can get away with increasing the thickness local to the problem columns only. I would go with something other than adding shear reinforcement.
UcfSE,
I would probably go with increasing the thickness of the mat locally at the problem column. And I would like to know if there is any specific reason for not considering the shear reinforcement. Is it going to be expensive? Just curious
DaveAtkins
You have the option of using the old load combinations and resistance factors if you follow ACI 318-02 Appendix C - "Alternative Load and Strength Reduction Factors."
