parameterisation of workbench geometry
Hallo everyone,
I am new in working with Ansys. I have already done some simulations with Ansys Workbench and have started working through the (very good) tutorials for Ansys now. Because I like Workbench better than plain Ansys, I have a question, if what I want to do, is somehow possible in Ansys Workbench:
I want to perform optimisations. I'd like to create a shaft, let Ansys find the places of minimum and maximum stress and change the shaft's geometry in the found places according to some rules I have created.
I have seen a parameterisation-tutorial for Ansys (but not worked through it yet). My question is, if my plan to optimise via rules working with stresses found in a (previous) simulation is doable in Workbench?
It would be great, if someone could tell me a "yes, it's possible" or "no, maybe in Ansys or in Ansys Workbench xx.x in the future".
I'd be happy for hints and tips.
Thank's in advance and best regards
       Mario
RE: parameterisation of workbench geometry
Hello
optimization within Workbench can be done with the DesignXplorer and DesignXplorerVT modules, but I don“t know if you can implement rules other than "minimize the maximum stress for this weight" or similar.
Hope it helps
Cheers
Hello again,
thank's for the quick reply!
Yes it helps alot, because I can go back to work with renewed enthusiasm and two handy keywords to search the (large) help-file :)
Thank's and best regards
      Mario
Yes, you can, see "shape optimisation tool" which reside on the toolbar.
DesignXplorer (and the VT version) helps you to find the so called "surface response", I mean the sensitivity of parameter(s) vs the goal function (like max equiv stress).
Thank's, I will look closer at the shape optimisation tool, too!
Though, doesn't that tool optimise "via random" only?
     Mario
See the following examples from Ansys Verification Manual:
VM155 - Shape Optimization of a Cantilever Beam
VM157 - Optimization of a Frame Structure
Also read:
"ANSYS Advanced Analysis Techniques Guide ANSYS Release 9.0"
