Valve adjustment?
Valve adjustment?
Is it better to set the valve lash ajustment on mechanical lifter design engine with the engine warm and off or actually running at operating temperature?
Overlook the inconvenience of oil throwing around.
RE: Valve adjustment?
Mike Halloran
Pembroke Pines, FL, USA
Mike Halloran
Establish thereby what works for the gap. Shut off engine, cool down, add oil, measure gap "cold" on the "test" cylinder, set the rest to the same cold gap.
Oh, and don't mix up plug wires in between...
