use for material
use for material
is there any use for a material with a temp rating of about 300 degrees. no flame support. excellent thermal insulation ( almost no heat transfer by conduction), non metallic, vibration damping. material is pourable and settable and conforms to any mold. room temp casting although a hot water bath improves it. compression strenght about 2000 psi. tensile about 400. cost 6 dollars a liter. easily colored. feels warm to the touch. density range 1.35 to 1.8. waterproof.
some mixes can be completely dissolved in situ with certain solvents.
