Anti-dive if side view IC is ahead of vehicle
I'm designing a small, one seat, motorcycle engine powered offroad vehicle. Double wishbone front and rear w/ about 20in. total suspension travel. The front lower wishbone outer pivot will be connected at spindle height to the front upright (for increased ground clearance and packaging). I'd like the wheels to travel rearward a bit as they move up for a more compliant ride. This forces the lower wishbone to be tilted upward in front because the wheel path, (in side view) is governed only by the lower arm, in this scenario. For packaging reasons it will be dificult to tilt the upper arm even more than the lower to get some anti-dive. But due to the low spring rate and light damping anti-dive is important. For packaging reasons the side view instant center ends up infront of the vehicle. How do you compute % anti-dive with this setup?
Second question I can see why it might be dificult to get 100% anti-dive without seriously affecting the ride but 100% anti-squat seems possible are there any drawbacks to achieving it?
Damien
Damien
RE: Anti-dive if side view IC is ahead of vehicle
As for 100% anti-squat at the rear: Go for it! There are those who contend that such a setup tends to "lock up" during braking, but I've yet to have anyone provide a mechanism for such a response. It's like switching channels on the idiot box: There are braking geometry considerations and then there are acceleration geometry considerations.
