Standard Corrosion tests
Hi, I believe I may have developed a coating that can inhibit some forms of corrosion. The problem is that I have little knowledge of any straight-forward tests for 316L, titanium, NiTi, etc..
The only thing i have been trying is high pH, high-ionic strength salt solutions which don't work very well on stable metals. Thanks for your help.
RE: Standard Corrosion tests
ASTM B 117
STANDARD PRACTICE FOR OPERATING SALT SPRAY (FOG) APPARATUS
http://www.welding-advisers.com/
One caution is that the test does not reproduce well.
If you want a real good test you will need to learn about electrochemical testing.
Corrosion, every where, all the time.
Manage it or it will manage you.
http://www.trent-tube.com/contact/Tech_Assist.cfm
