Adjcetives --> Nouns and uncountable nouns
Sometimes, I don't understand why some adjcetives are considered as nouns. For example, locals refer to people living locally, chemicals refer to different/several types of chemical substance....
In addition, I am also puzzled why some uncountable nouns become countable nouns, e.g. bearings, nosings or settings..
RE: Adjcetives --> Nouns and uncountable nouns
The function of an adjective is to provide additional information about its associated noun.  Adjectives always are associated with a noun, but never become a noun.
In you "living locally" example, living is a verb, and locally is an adverb - it modifies the associated verb.
Most nouns gain the s when refering to more than one.
what he meant, I think, is that the word "local" seems to be an adjective which is being used as a noun.
Hi ivymike.
Thank for your reply. Since I'm not a native speaker of English, I find it is difficult to understand why adjectives can become nouns. Is it new English??
steveyeung - English is a living language and in large part, if a reflection of how it is used, provided such usage reaches a consensus.  New words are constantly being added to English, with a very recent example 'blog' which can be either a noun or a verb, depending on how it is used.
Do you have a blog?  (Noun)
Do you blog?  (Verb)
I suspect, although I can't refer you to specific sources, that at one time, local was only an adjective, but through colloguial use over time, it became apparent that, in context, you didn't need both the adjective and the noun.  Due to perhaps laziness, the extra and un-necessary noun was dropped, and the adjective became the noun as it now functioned as the noun.  That usage became widespread, achieved a consensus as being valid, and thus became part of living English.
Good Luck
As a circle of light increases so does the circumference of darkness around it. - Albert Einstein
At school we were told that in such cases the noun is understood.
To use your example "He is a local (person)"
I think "chemical" however, is a noun in its own right, such as "a corrosive chemical"
Jeff
Notnats:
You mean locals refer to the local people????
Steve
The first rule of English is that there is an exception to every rule.
And yes, local can refer to the people... As in, "Oh, he's a local." or "While driving through Little Rock, Arkansas, we ran into a few locals at the local watering hole."
Even the smart modern fast computer spell checkers can't keep up.  My spell checker always red lines the word google whether I use it as a noun or a verb, which I do quite often.
rmw
English has a very productive mechanism of changing the part of speech of words.  One of my favorite "Calvin & Hobbes" quotes:  "Verbing weirds language."
Hg
Eng-Tips guidelines:  FAQ731-376
steveyeung
Colloquial English usage is sometimes difficult to understand.  Frequently, phrases are shortened for ease and convenience, and the parts of speech suffer as a consequence.  In your example, …”locals refers to people living locally”… , is colloquial usage in which the word residents is implied.  It would be more correct to say “…local residents refers to people living locally …”  Another example, trains that make local stops are also called locals simply because it is easier to say - .  So, if you are standing at the train station and someone asks you if “…the local stops here?…” is he asking whether the person who lives locally stop here?  No.  In colloquial phrases, the context should make the meaning clear otherwise, the implied words should be explicitly stated.
In your second example, chemicals is not an adjective.  It is a noun.  A noun is the name of an object class.  In your example, chemicals is an object class even though the chemicals may be of different/several types.   Chemical can also be an adjective if it is used to modify a noun.  In the phrase chemical compound , compound is the noun (object class) and chemical tells you what kind of compound.
Your examples of countable nouns are plural nouns.  The fact that they are plural does not mean that they are countable.  It is only necessary that there be more than one.  For example, there are an infinite number of points in a circle.  The points are not countable but we know there are more than one so points is plural.  Now, sometimes when we don’t know the details of a situation we speak in generalities and we assume the plural.  For example, if your car were stolen, you might call the police and say …they stole my car!, assuming the plural they.
Hope this helps.
RGasEng
Thank you for your hints
