Tenses
Tenses
I am a graduate engineer and have to do training report every three months. However, I faced a question about what tense should be used in my reports. Normally, the reports cover what I did over the last 3 months, in general, the tense should be past tense. However, when I talk about the client of a project which has not finished when I write the report. What tense should be used?
(For example: Over the last three months, I have been devoted to a project of which the client [is/was] XX company)
RE: Tenses
My first thought is that since the report is to describe what happened during the last three months, then I would lean towards past tense.
When you come across situations like your example, I would try to remove tense whenever possible.  "Over the last three months, I have been devoted to a project for client XX company."  If that is not possible, I would stay in past tense because during that period, company XX was the client, and to maintain consistency.
Good Luck
As a circle of light increases so does the circumference of darkness around it. - Albert Einstein
RE: Tenses
Thank you for your help.
However, my understanding is (may be wrong) the project has not finished yet. I am still working for this client. Last time, when faced the same situation and used the past tense in my training report, my training advisor said I had to use present tense....It is very confusing....
RE: Tenses
I guess the argument for using the present tense is that you are writing the report now, however you have to consider that the report may be read some years into the future and that events happened in the past. Unfortunately business today is short sighted and can't see that far ahead. I'd write the report how best you feel it should be written. You can guarantee that supervisors will rewrite it no matter what style you adopt. It gives them that air of authority.
corus
RE: Tenses
I would say past tense is appropriate when writing about things that have occured, and future tense if writing a "look ahead".
"Last month we completed testing of the hydraulic system.  Next month we plan to validate the control software."
RE: Tenses
Client was xx company (was and is no longer)
Client has been xx company (was and still is)
RE: Tenses
Thank for all your advice.............
