Phosphate acid chemicals
Can someone help me with the question: Do solutions of phosphate acids in waste water systems contribute to mild steel corrosion. I use an Phosphate acid chemical in my powerwash system to spray clean mild steel components, or will there be an protective layer of phosphorus present to protect against corrosion.
RE: Phosphate acid chemicals
Phosphate conversion coating providing mild resistance to corrosion are being applied to mild steel using specially formulated solutions.
http://www.welding-advisers.com/
