NX2 Detail view
NX2 Detail view
I work with the "circular boundary on parent view has label with leader" setting for detailed views.
Is there a way to relocate the arrow once the view is placed ?
RE: NX2 Detail view
RE: NX2 Detail view
RE: NX2 Detail view
Gary Welzenbach wrote:
> So you are able to move the leader around the diameter of the Detail view? I
can
> move the leader, but not where the arrow is connected to the detail. That point
> stays fix. I need a way to be able to rotate or relocate the arrow around the
detail
> diameter.
John Baker wrote:
Move the label while holding down the "Shift" key.
RE: NX2 Detail view
RE: NX2 Detail view
It isn't very elegant, but you can change the "label on parent" setting to "boundary" (i.e. no label) and make your own label with the annotation editor. Then you can set the arrow origin wherever you like.
RE: NX2 Detail view
RE: NX2 Detail view
You can do this after the fact and replace the boundary curve for view with the sketched circle. you can just expand the view and rotate the circle by using transform to change the arrow location.
Michael
