Model section produces invalid bodies
I have an assy that I need to section, when I try and create the section at a prescribed location I get the error that a section at that location will produce invalid solid bodies. I have also found the same thing when I tried to create a section veiw in a drawing I get an unusual section view, ( same assy, same location). If I move in one direction or the other a little, the problem goes away.
Any ideas?
TAP
Any ideas?
TAP
RE: Model section produces invalid bodies
Another potential source of trouble is a complex edge (such as a cut edge of a lofted face) right on the section line.
As you have found, simply offsetting the section line a tiny amount (say .001" or less) will allow creation of the section view.
Helpful SW websites every user should be aware of FAQ559-520
How to get answers to your SW questions FAQ559-1091
Send this into your VAR, maybe you have the model that will determine the error and get it fixed.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Is it a revolved feature ?
I've come across this when the section passes through the start/end of the revolve.
beachcomber
For instance, the end of a loft that is created with a point for a section would be a problem if the section cut through the same plane the point was placed in creating the loft. (How can you section and display a point?)
Jeff Mowry
www.industrialdesignhaus.com
Reality is no respecter of good intentions.
TAP
Not sure what else to tell you there isn't enough info to help you with this problem further.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
