User Defined Symbol Scaling?
Hi Guys,
When I insert a user-defined symbol, it comes in slightly larger than when it was created.
I've ensured that the Symbol Factor during creation is at default 0.0. I've also played with changing it to 1.0, but still with no luck.
Any ideas?
Many Thanks,
Andy
(Using UG NX2)
Design Draughtsman
Biomet Ltd
www.biomet.co.uk
RE: User Defined Symbol Scaling?
This is a bit of a hack, but you could measure how much the symbol is being scaled up, then scale down the original by the same factor and re-create it.
