designing reinforcement
hello.I want to know how to design a 2-plate crotch plate reinforcement . I don't know what to do with the parameters like dw,db,dt which I have obtained them from awwa c200-91 M11 manual.
Thnx
Thnx
RE: designing reinforcement
You may check, if this design code applies, ASME B31.3 section 304.3.3 or use it as a reference.
Regards.
If the pipe is of any size, FEA would be one approach- it wouldn't take a real sophisticated approach to get useful results.
