bolt grades and kips to foot pound conversions
Hi, I have two questions. First off what grades are A307, A325, and A490 bolts? Second what is the formula to convert kips to foot pounds? I appreciate your time and information. Thanks, Cory
RE: bolt grades and kips to foot pound conversions
A kip is 1000 pounds. You can't "convert" it to foot pounds. You can multiply it by the length of a lever arm to get torque.
Mass/Length
1 lb/ft = 1.488 kg/m
1 lb/yd = 0.4961 kg/m
Mass/Area
1 lb/ft2 = 4.882 kg/m2
Force
1 kip = 4.448 kN
Moment
1 kip-in = 0.113 kNm
Stress
1 kip/in2 = 6.895 MPa
Modulus
1 in3 = 16387 mm3
Second Moment of Area
1 in4 = 416231 mm4
A325 is a high strength heavy hex structural bolt with an allowable tensile stress of 44 ksi and has 3 different types (Type 1, Type 2 and Type 3).
A490 is a heat treated heavy hex structural bolt with an allowable tensile stress of 54 ksi.
here are a couple links from yahoo "torque preload" ...
http://euler9.tripod.com/fasteners/preload.html
ht
ht
http://www.tribology-abc.com/calculators/e3_6a.htm
good luck
Keep in mind that US customary weight units are often confused with SI mass units.
Jeff
Jeffrey T. Donville, PE
TTL Associates, Inc.
www.ttlassoc.com
