Am I conservative?
Am I conservative?
Hello!
I have a composite panel of 12 plies. I'm studying its buckling and stiffness resistance.
The problem is that the FEM which I am using to read flows (to enter in my calculations) has 8 plies.
It is supposed that a panel with 12 plies takes more load that the 8 plies' one. So...Am I making a mistake?? Is there any way to use the available FEM without mistake?
Best regards!
Best regards!
RE: Am I conservative?
A little more information would be helpful.
Garland E. Borowski, PE
Borowski Engineering & Analytical Services, Inc.
www.borowskiengineering.com
good luck
Both panels only have in-plane loads.
To sum up, the only difference between the panels is the number of plies. Does the thickest take more load than the thinnest?
The strength, stiffness, buckling load of the 12 ply panel MAY be higher than the 8 ply panel, but it depends on the stacking sequences of the 2 panels. Thicker is not always better if the layups are significantly different. If the 12 ply panel has the same 8 center plies as the 8 ply panel, then it is very likely that the 12 ply panel will be stiffer and stronger.
http://
If you understand what this is doing, I think you can get your answer. This provides failure envelopes for first ply failure. it includes graphs for various planes.
David R. Dearth, P.E.
Applied Analysis & Technology
