Writing a value in a cel of Excel
In Access I have the follow VBA-code:
sub test()
Dim ex as New Excel.Application
ex.DisplayAlerts =False
ex.Workbooks.Open "c:\test.xls
ex.Range("A1").value= "Example"
ex.ActiveWorkbook.Save
ex.Quit
ex.DisplayAlerts = True
Set ex = Nothing
End Sub
If Excel is get starting and the workbook test.xls is not open
this code workt perfect.
But if test.xls is open this code do not work, the value of
cel A1 is empty.
I want to allways write the value to Cel A1 if test.xls is
open or not opened.
Can somebody helpme?
Greetings,
mulderm
RE: Writing a value in a cel of Excel
Just thinking outloud here, but
if excel is not open it works because you are able to create a new excel app named test
if it is already open then you are not able to create the new app name test because it is already open
open a excel file with a different name than test ..see if  the macro runs
looks like you need a if - then check to bypass creating a new file if it is running
How created a If- Then check for this?
Is there code to first close the open test.xls (if opened)
and then running my code?
mulderm
Just a bit of clarification:  The line of code
CODE
creates a new instance of Excel.  If Excel is already running, then a second instance is created.  If the workbook Test.xls is open in the first instance of Excel, then opening it via your code in the second Excel instance results in it being opened read-only.  Therefore, changes made will not be saved.  The following procedure will detect whether
a) Excel is already running
b) Test.xls is open
and respond accordingly:
CODE
Sub OpenExcelWorkbook()
Dim XL As Excel.Application
Dim Wkb As Excel.Workbook
Dim MyWkb As Excel.Workbook
Dim TargetWorkbook As String
Dim ExcelRunning As Boolean
Dim MyWorkbookOpen As Boolean
   TargetWorkbook = "C:\Test.xls"
   On Error Resume Next
   Set XL = GetObject(, "Excel.Application")
   If Err.Number <> 0 Then
     Err.Clear
     ExcelRunning = False
     Set XL = CreateObject("Excel.Application")
   Else
     ExcelRunning = True
   End If
   MyWorkbookOpen = False
   If ExcelRunning Then
     For Each Wkb In XL.Workbooks
       If Wkb.FullName = TargetWorkbook Then
         MyWorkbookOpen = True
         Set MyWkb = Wkb
         Exit For
       End If
     Next Wkb
   End If
   If Not MyWorkbookOpen Then
     Set MyWkb = XL.Workbooks.Open(TargetWorkbook)
   End If
   MyWkb.ActiveSheet.Range("A1").Value = "Example"
   MyWkb.Save
   ' The following is optional, depending if you want to
   ' leave the workbook open if it was open already.
     MyWkb.Close
   End If
   If Not ExcelRunning Then
     XL.Quit
   End If
   Set XL = Nothing
End Sub
Mike
This is pretty well covered in Excel Help, including examples you can cut and paste.
Mike,
You´re the greatest!!!!
This code is exact what I means,works perfect.
Very, very thanks from the netherlands.
Greetings,
mulderm
