Any good gd&t tutorial suggestions ?
Hi all,
Could anybody suggest any good gd&t book titles that are not too cluttered or complicated, and that have good application exercises?
I've seen a bit of some e learning sites...
any prefered ones ?
Hope to get some replies.
RE: Any good gd&t tutorial suggestions ?
www.geotol.com
"Fixed in the next release" should replace "Product First" as the PTC slogan.
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
Geo-Metrics III by Lowell Foster.  Hands down the best book on GD & T out there.  Check www.superbookdeals.com for the cheapest prices on books I've seen on the internet.
Good Luck!
Geometric Dimensioning and Tolerancing: Applications and Techniques for Use in Design, Manufacturing, and Inspection
by James D. Meadows
It more of a "textbook" than Foster's book but gives some very detailed explanations of GD&T concepts as well as some examples that aren't found in either the ASME standard or the other guides to GD&T. A copy of the ASME Y14.5M-1994 standard is also good to have around. I actually refer to the standard more often than any of the other GD&T books on my bookshelf.
Also chack out http://www.tec-ease.com/gdt-tips.htm for some good GD&T tips.
Good luck...
Giuseppe Sagolla
Sr. Mechanical Engineer
Immunicon, Corp.
SW2005SP4.0; XP Pro SP1.0
hp xw4100; P4 3.2 GHz, 3GB RAM
NVIDIA Quadro4 980 XGL
opse0,
   Go the the source.  Get a copy of ASME Y14.5M-1994.
   The actual, official standard is fairly readable.  Any time any other references disagree with the standard, they are wrong.
                   JHG
