Rebar properties
Rebar properties
We are looking for electrical data on rebar; specifically, the electrical resistance of #3, uncoated.
RE: Rebar properties
I wouldn't think it would be that hard to test.
Depending on the level of accuracy required, you could test a given length with freshly cut ends and reduce the length as appropriate to get resistance per unit length data for regression / statistical analysis. Repeat for several samples from different bars/production lots if possible. Properties may vary across different manufacturers if the type of steel alloy varies.
Jeff
Jeffrey T. Donville, PE
TTL Associates, Inc.
www.ttlassoc.com
Steve Braune
Tank Industry Consultants
www.tankindustry.com
Dik
