showing open and close strategy
Hi All Users:
I’m looking for the best strategy to show a cabinet assembly with door open and door closed.
I can create a family table of the hinge one open and one closed and then a family table of the cabinet assembly with my generic have both versions of the hinge and having 2 doors in the assembly and door 1 constrained to the open hinge and door 2 constrained to the closed hinge.
Is this my best way to approach this to double up on my hinges, doors, and assemblies?
I’ve also tried using the flex feature with the hinge but it causes problems with my pro process steps not displaying the hinge in the drawings.
-Caper-
-Caper-
RE: showing open and close strategy
I think you can create a open and a close door position in a process steps.
-Hora
http://www
from artical:
"Assemble all of the instances in the family table to the top-level assembly."
so Marty is doing it basicly the same as I know what will work, but is that best way to go about this?
still searching.
let us know what you come up with
Lets say your assembly is CABINET.ASM and the hinge is HINGE.PRT.
First, in HINGE.PRT, create a parameter called ANGLE (or something similar) and equate the dimension that controls the hinge angle to this parameter.
Then, go into Tools->Program and select Edit Program
Add the line in red:
INPUT
ANGLE NUMBER
END INPUT
Say yes to incorporating the changes, and have it regen with the currrent values for now.
Now, open up CABINET.ASM.
Go into Tools-> Program and Edit Program once again.
Here is a sample of what your Pro/Program might look like:
INPUT
HINGE_OPEN YES_NO
"Is the hinge open?"
END INPUT
RELATIONS
IF HINGE_OPEN == YES
HINGE_ANGLE = 90
ELSE
HINGE_ANGLE = 0
ENDIF
END RELATIONS
EXECUTE PART HINGE
ANGLE = HINGE_ANGLE
END EXECUTE
... (The Pro/Program proceeds to add all the features and components)
The EXECUTE statement allows you to execute any Pro/Programs in lower-level components. You can only equate the ANGLE parameter to HINGE_ANGLE if it is designated as an input parameter in HINGE.PRT's Pro/Program.
Hope this helps.. let me know if it works for you..
Michael
Here is what I've decided to use.
Hinge assembly with family table Hinge_OPEN & Hinge_CLOSE
Door assembly with family table Door_OPEN & Door_CLOSE. With generic assembly having both hinge assemblies.
In my Cabinet assembly I use Door_CLOSE assembly but when I create the PRO/Process assembly I add Door_OPEN assembly and omit using the Door_CLOSE assembly.
The reason for my decision is the door is open for assembly purposes only while the finish product will have the door closed.
-Caper-
