Reduction gear 1000:1, is it possible
Hey all, I have this problem that I need to reduce the speed of a motor from 1000 rpm to only 1 rpm. Is this possible in reality? And if there is a gearbox that does this, I want to knnow where to find it.
RE: Reduction gear 1000:1, is it possible
Take a look at harmonic drives:
http://www.harmonic-drive.com
http://www.harmonicdrive.de/en/2_2_3.htm
The existing rotary vector drive can have
a reduction ratio of 1000, by using the
involute gears for its 1st planetary drive,
and cycloid, harmonic or Ikona gears for
its 2nd planetary drive.
But I also have several questions for you:
(1) Does it require to be back-driveable?
(2) Is this a plastic gearbox or metal gearbox?
(3) What's the approximate dimension?
If it's a plastic box, I don't know at the moment
whether harmonic drive can be used.
Good luck!
The answers to paulliu's questions is as follows:
1- No, it does not require to be back-driveable.
2- It is a metal gearbox, not a plastic one.
3- I do not have any restriction on the dimension side.
Now for a speed reduction ratio of 10,000, a recent
example I saw, employed two gearboxes with a speed
reduction ratio of 100 for each of them, and each
of which may use the harmonic gear drive, or worm-gear
drive, or involute planetary gear-drive et. al.
http://www.globe-motors.com/home.html
About using 2 gearboxes, it seems like a good idea. Any advise about where to get them, baring in mind that I will need a max output torque of 60 Nm
100Nm/10,000 = 0.01 Nm = 0.074 ft-lb input < 1 inch-lb
Which puts you at the really smallest section of speed reducers for the input side and even the secondary one can be a less than an inch in sizing. (worms speed reducers are determined by the distance between axis of the worm and wheel)
Youll find those in the Grainger catalog as sub-fractional speed reducers
SACEM1
