pump station peak factor
Does anyone have any information on ideal peak factors to use for sewer pump station design flows. Ten States has a chart for peak factors based on population but this is excessive and seems to be more aclimated to large plant flows. The state regulators here are now requiring a minimum of 4.0 factor and this is causing problems with long detention times in wet wells. I have researched many other cities and have found that factors range 2.5 to 4.0.
RE: pump station peak factor
good luck
