Arc Lengths
Arc Lengths
Is there an arc length dimension? I would like to create a dimension to constrain the length of an arc. Right now I have dimensioned theta and the radius. I insert the radius and then make theta equal to the radius divided by the desired length (it is radiuns). This works but it would be better if I could just have the length and radius.
I know I can use the measure tool to find the length afterwards, but is there a dimension tool that does the same thing. Right now I have to hide the theta dimension and then create a new driven theta dimension and override the text with the length. I want the viewer of the drawing to see the arc length and radius only. So to put it simply a constraining length dimension would be nice, but a driven length dimension is acceptable.
RE: Arc Lengths
RE: Arc Lengths
I think you'll need to constrain/define your radius as well.
Jeff Mowry
www.industrialdesignhaus.com
Reality is no respecter of good intentions.
RE: Arc Lengths
