need vendor names for natural gas booster
I have phoned around many of the specialty vendors I know of and have not been able to source a manufacturer for a natural gas booster.  Maybe someone here can point me in the right direction.
Application:  Increase pressure of 30 scmh of natural gas from a pipe line from 1000 kPag (145 psig) to 9000 kPag (1305 psig) for injection into an oil well.
Can anyone recommend a vendor and the type of machine I should look into?   I thought of a recipricating compressor or gas pump but can't find a vendor to do the low flow and high pressure.
Thanks.
RE: need vendor names for natural gas booster
This is definately a recip application.  The class of the industry is Ariel at www.ariel.com, but there are any number of other manufacturers and there are thousands of packagers anxious for your call.
David Simpson, PE
MuleShoe Engineering
www.muleshoe-eng.com
The harder I work, the luckier I seem
Gas Packagers, Inc. out of Denver, CO could possibly help.  I've worked with them before.  The contact there is Dave Moss, 303-297-8100 x3012. http://thecompressorcompany.com
Thank you all for your reply.  I'd follow up on the lead on Monday when I get back to work.  Thanks again.
