Equipment sensivity
Equipment sensivity
Hi all:
I want to ask if i can use an accelerometer with a different sensivity than original, and if yes, do i have to make any correction, how?
Thanks and luck
Thanks and luck
RE: Equipment sensivity
More generally, yes, you can use different sensitivities, but if you use a different model of accelerometer then it may have a different noise floor, max output, frequency response, and of course mass.
Cheers
Greg Locock
if you're simnply trying to identify resonances, for example, actual amplitudes aren't particularly important, are they?
In which case, accelerometer calibration isn't particularly important either.
