Measuring Nickel Plating Thickness
I've run across this a couple times now and am wondering if there is a non-destructive method to measure the thickness of the nickel plate (this is a repair to a bore)? The base material in this particular case is 30NiCrMo16-6. This is a landing gear part with a nickel repair (without paperwork) and I need to verify nickel thickness.
If there exists such a method could it be used on other base metals? Please forgive me for my ignorance. I usually deal with aluminum structure.
RE: Measuring Nickel Plating Thickness
http://www.defelsko.com/pt6kFR.html
Cory
I'll look into your suggestion.
Is there any other method to measure nickel thickness without using destructive methods?
Any help is greatly appreciated
http://www.oicm.com/applications.php
I'm sure it's not cheap but this can do the job surely:
http://www.oxford-instruments.com/ANLPDP743.htm
This looks promising. I'll look into these. I appreciate your input.
