thermoplastic sulfur concrete
I am trying to find out where to buy sulfur concrete. I read that it achieves compressive strength in excess of 9000 psi in one day of casting. Does anyone know about it or any web sites for it?
RE: thermoplastic sulfur concrete
Sulfur was tried numerous times as an admixture in both PCC and asphaltic concrete with various results, none of which seemed to be commercially viable. It has to be heated into a fluid mix and hardened to achieve anything like the strengths you referenced, which makes it impractical to use in a mixture with PCC.
Can be used as a leveling medium, but you have to remember that it leaches and the leachate can be highly acidic, thus creating corrosion problems.
We are a Sulfur Cement & Concrete producer in Iran. You can check our web link http://absazeh.hypermart.net
Please do not hesitate to contact us for more information.
Your Faithfully
A.J.Ghajar
arash_ghajar@yahoo.com
