/3gb switch
/3gb switch
/3gb switch
Will the /3GB switch work in Windows 2000 ?
RE: /3gb switch
That is what I was thinking.  We are having memory trouble with some of our larger drawings. When we set resolved and turn Large Assembly Mode off we get a not enough memory error.
RE: /3gb switch
I have tried to open it on both a 1gb (original machine) and a 2gb station and get the same error on both.
I have a meeting here in about 5 minutes, when I get out I will give you the specs for our work stations maybe you can offer some insight.
RE: /3gb switch
It might be time to consider upgrading to XP for two reasons:
1) The memory issue.  (Also see thread thread559-107229)
2) SW2006 is the last release that will support Windows 2000.
RE: /3gb switch
I believe SW give a "out of memory" error when approaching the 1.6 barrier, was that the error you got or did you get exactly the message you stated?
Might be obvious, but did you check your page file settings? I happend to me once, after I re-installed I forgot to set it...
Stefan Hamminga
Mesken BV
2005 Certified SolidWorks Professional
Mechanical designer/AI student
RE: /3gb switch
My systems are as follows:
P4 3.0 ghz
2gb ram / 1gb ram
Quadro 4 980 XGL Video 128mb / 6722 driver
SW05 SP2
The difference between the two machines is the ram and the video card. But both machines have the same video driver version and video ram.
Yes the error message is the "out of memory"
Drawing file size is 32mb
RE: /3gb switch
Try updating the driver, SW has a new approved driver.
Also try running a "Modify" on your system - FAQ at my website.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
