Steam Boiler Water Treatment
Dear All,
on our plant we’ve got a new boiler with an inlet water softener.
Can you please give your thoughts on:
1) If we use a scale/oxygen inhibitors for this boiler how to measure their performance/effectiveness (samples/analysis??!)
2) Would this be sufficient or we have to refer to the boiler manufacturer/company specialized in the water treatment etc
thanks,
Jeyx
thanks,
Jeyx
RE: Steam Boiler Water Treatment
do you know if there are graphs etc, which helps to define if the scale can still precipitate on the boiler walls at the given temp after softening ?
all the best,
Jeyx
There are standard asme guidelines for all operating boilers based on operating pressure that one should adhere to. We can send information if needed to help. You boiler manufacturer guide should have some genral guidelines. More will probably be needed.
If interested in more information, please reply and we can send.
www.ajchemllc.com
John
all the best,
Jeyx
