Parker Fluid Connector Downloads??
Hello all.  Looking for a site, free if possible, that will allow for downloading 3d Parker Fluid Connectors.  Any help is greatly appreciated.
RE: Parker Fluid Connector Downloads??
Contact the Parker company to ask if they know of a download site.
Also check the "Helpful SW websites ...." faq below.
Helpful SW websites every user should be aware of FAQ559-520
How to get answers to your SW questions  FAQ559-1091
I don't know if they're Parker or not but McMaster-Carr does have 3D models of some tube fittings.
I hope Parker's changed because I found them decidedly unhelpful when I was on a similar quest several years ago.
Check 3D Content Central -- you may get lucky.
Bring back the HP-15
www.hp15c.org
Parker has cad files, including solid models, available on their web sight. Here's the link to the Tube Fittings Division.
http://www.parker.com/ead/cm1.asp?cmid=682
Look under the "Products" menu, on the top left for CAD Models. You will need to register, but it is free.
The mold component manufacturer DME company had a great CD a few years ago. They resell Parker components.
They have 2D & 3D CAD files.
http://www.dme.net/wwwdme/index.asp
David
I think Parker has IGES and STEP available for downloads but not native SW files. You might try SSP Fittings or Swagelok Fittings. I know Swagelok uses SW as there CAD software.
Links:
http://www.sspfittings.com/
http://www.swagelok.com/
Macduff
Colin Fitzpatrick
Sr. Mechanical Designer
macduff's SW page
Inhouse System
Pentium(4)2.80GHz
Ram 1.00 GB
SW2005 Office SP 3.1
Windows 2000 SP4.0
NIVIDA Quadro4 750 XGL
We got a bunch of parker fitting off their website yesterday. They do come a step or igis. but work really well if you run featureworks on them.
