2006 Error on Startup
I get this error on startup
"Error: the database file'N:\Solidworks Data\lang\English\swbrowser.mdb' is not the expected version (10.05).
I did run the update file on this Toolbox so I am not sure what is going on.
Any help would be greatly appreciated.
Chris
RE: 2006 Error on Startup
Try running the Modify on your install - See my website \Tips and tricks on how to do this.
REgards,
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Scott
Tried what you suggested and I am still getting the error.
Anymore ideas?
Chris
Backup your Toolbox Browser and the the current mdb file in the toolbox folder. Then do a clean uninstall and reinstall of SW and Toolbox. Once you reinstall you can take your backup and replace the files with it.
See FAQ's
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
I had the same problem when I installed 2006. I did the install as a new install but left 2005 alone. I used a diffrent folder for the Toolbox in 2006 so the two would not be over written. When I ckecked the folder where the files that was being referanced there was nothing in it just plane empty. Still have not persude getting it fixed though becouse I have been short on time.
