PQR FOR TUBE-TUBESHEET JOINT
HI
Please clearly specify that ACCORDING TO asme ix, what are the essential requirements of a PQR to qualify the WPS of a tube-tubesheet joint?
I also need information regarding weld joint(thickness of tube and tubesheet) of test coupon to qualify WPS.
Awaiting your early reply.
RE: PQR FOR TUBE-TUBESHEET JOINT
I would suggest that you have a small mock-up of several tube to tubesheet joints to assure proper weld technique in depositing the weld.
Tube Pitch(Square or Triangular) and ligament,Tube O.D and tube thickness.Smaller diameter tubes with lesser wall thickness requires more precise control of welding parameters.Also profile of the weld joint is important, e.g only fillet weld or groove & fillet weld , the tubes could be projected,flush or underflush etc. Some clients requires POR's on each/specific job requirements.Clients specifications are more specific for Tube to Tubesheet Qualifaction.
Hope it will help.
