Flow direction for Orifice meter in vertical pipe
Why is it important that if I have liquid, the flow direction should be from bottom to top. and opposite in case of gas; when using orifice flowmeter in vertical run?
RE: Flow direction for Orifice meter in vertical pipe
Similarly for gas streams; they may carry blobs of liquid or particles, and you want gravity to help send them on their way.
Mike Halloran
Pembroke Pines, FL, USA
Which is more prevalent?
JMW
www.ViscoAnalyser.com
