How do you window select importedcurveX?
Lately I have been importing a lot of 3d wireframe IGS to convert them to a solids. When I try to use the "Sketch->Convert" command on the "importedcurves" I have to select every single entity directly. How can I change it so that I can select them by a window?
RE: How do you window select importedcurveX?
Maybe the problem is in the other application you are using, or if you are using SW for this, then the question is how are they before you export... single or separate enitities?
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
When I am selecting entities to convert to sketches I can select individually ImportedCurve187 or I can select it in the graphic section but I cannot select many entities at once by a selection window. In some cases using the window would save hours over individually selecting things.
Helpful SW websites every user should be aware of FAQ559-520
How to get answers to your SW questions FAQ559-1091
Rather than doing a shift select of importedcurve1 - importedcurve516 the circles that I want might be(and probably will be)in the tree:
importedcurve3
importedcurve78
importedcurve193
importedcurve624
importedcurve1133
... etc
So shift select wouldnt be very helpful. I also have no idea what importedcurve2171 is until I select it and see what entity highlights.
