Reducing Power Consumption in a PC
I can't seem to find any power supplies that are certified to work at 400 Hz (on aircraft) that are larger than 300 Watts. I'm building systems that may exceed this. What are the power hogs in a computer system, so that I can maybe scale them back to reduce power consumption?
Thank you.
In particular does using a video card with passive cooling use a lot less power than one with a fan?
Thank you.
RE: Reducing Power Consumption in a PC
