High Temperature Ball Valve
I´m looking for a 3 way diverter, 1/4" Max pressure 10 Bar,
Temperature: 500 Degree Celcius?
RE: High Temperature Ball Valve
I think that this may be a bit hopeful - have you considered using 2 off on/off units piggy-backed so that they are operated by the one operator - one opening whilst the other closes?
Assuming that you are looking at a ball valve, such units tend not to operate on the same principal as their soft seated cousins.
You might want to try these people. If you don't see it give them a call.  This is the Haskel bunch.
http://www.butech-valve.com
Go to www.flow-tek.com Look at thier multi port valves.
