PID capabilities with Visio 2000
I just installed Visio 2000 and dont seem to have the flowchart--->Piping and instrumentation option.
Does anyone know if a)wether it even should have this option
b) can i download and update or add-on to be able to use it
c) can it be extracted from visio 2003(as i have this, it just wont install on win98 which i am currently running)
RE: PID capabilities with Visio 2000
You should be able to copy the Solutions folder contents from 2003 to 2000, although I'm unclear whether you need to downsave
TTFN
I will try to copy the solutions folder over, what do you mean by downsave?
TTFN
yeah no such luck....installed 2003 on another computer and it doesnt even have the solutions folder.
2000 wont open 2003 stencils either.
Surely there is a PID add-on for 2000 or something :S
My copy of 2000 came with with a variety of piping and instrumentation templates, so they do exist.
TTFN
If you can get AutoCad. Visio will work, you have to build a ton of your own stencils. My bigest complaint is in sharing files with/from others. The Autocad files import poorly and when you try to send Visio to many users their comment is Vis what?
StoneCold
http://www.mvps.org/visio/3rdparty.htm
"This page lists some of the hard to find Visio stencils, Visio templates and Visio drawings that have been found on the web"
