MS Access 2003 Validation Rules for Forms
Hello.
I'm have a database setup for our wedding. I have a form to enter RSVP responded (checkbox), RSVPInvited(##), RSVPAttending(##).
1st question.
1. I want to be able to disable the RSVPResponded(Checkbox) after I close down the form so I don't accidently uncheck it the next time I come into the form.
  b)  How do I add a running total to my report of the numbe of people responded?
2nd Question.
2. I want to make a validation rule in the form to check and make sure when I input the RSVPAttending(##) it is equal to or less than RSVPInvited(##).
  b)  How do I make a running total of RSVPAttending and RSVPInvited and add that to a form?
I tried putting this into validation for the RSVPAttending:
=[RSVPAttending]=[RSVPInvited] Or [RSVPAttending]<[RSVPInvited]
But it doesn't work.
3rd question.
How to I add a search to my forms so I can input characters into the LastName spot and it will come close to the location of the person. (ie. just like when u use your address book in Outlook).
Matt
RE: MS Access 2003 Validation Rules for Forms
Question 2-b Addition:
I can make two querys one having all the FirstName, LastName, RSVPResponded, RSVPInvited, RSVPAttending, but I can't add the this "SumInvited: Sum(Addresses!RSVPInvited" ect.  But If I create a new query from Address.Table I can enter "SumInvited: Sum(Addresses!RSVPInvited)" ect. and it comes out with the totals.
The only problem is I don't know how to combine both querys with these values to use in a Report?
