node mass problem
node mass problem
I met some weired warning message when I try to model a breakable bond:
WARNING: "In tied contact pair 3, node 291 on the slave surface UPPER_S has 9.1 times more mass than the mass of node 49901 on the master surface UPPER_M. Significant contact noise may result with the kinematic contact algorithm when the slave nodes have significantly
greater mass than the master nodes. Suggested workaround includes using mass-scaling to adjust the ratio of nodal masses."
Can someone tell me 1) why nodes have masses too? -- I thought only elements do; and 2) how can I solve it? -- My slace surface/nodes belong to a material much "lighter" than the master surface/nodes/elements.
Thanks very much.
Thanks very much.
RE: node mass problem
2) I think the answer is in your question (large differential mass). As it's only a warning, I wouldn't be concerned unless your analysis starts to fall over or your results are physically unreasonable.
See FAQ569-1083 for details on how to make best use of Eng-Tips.com
