Tolerance Display
Tolerance Display
I am using ProE 2001. In the part model at the bottom of the screen only displays first place through 3rd place decimals along with the angular. My company uses 4 place decimals, is there anyway to add a fourth place decimal to the display screen? The display is currently set ex: x.x +-0.1, x.xx +-0.01, x.xxx +-0.001, Ang. +-0.5
Each of these can be modified. Is there a way to add a fourth place dimension to be able drive the entire part model.
RE: Tolerance Display
display_dwg_tol_tags
yes, no
Sets the display of the tolerance tags that appear in drawings. This option does not affect the display of tolerances on dimensions.
default_dec_places
sets the default number of decimal places (0-14) to be displayed in all model modes for non-angular dimensions. it does not affect the displayed number of digits of dimensions as modified using numdigits. the number of decimal places of dimensions created in sketcher is controlled by the option ``sketcher_dec_places.''
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 4.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 1400
o
_`\(,_
(_)/ (_)
"There is no trouble so great or grave that cannot be much diminished by a nice cup of tea" Bernard-Paul Heroux
I tried both of the config files that you had suggested. I think that what I am trying to get at is where would I be able to adjust the 4th place tolerance for the entire part model if it is not displayed on the screen. There are only the 1st, 2nd & 3rd decimal place listed on the bottom of the screen to adjust the values, but not for the 4th place.
http://ww
It lists all the config options for Pro/e 2001. It's a config file option I know for sure I just don't have time to dig into it.......
Best Regards,
Heckler
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
o
_`\(,_
(_)/ (_)
We are setup using Ansi as the standard. Is there anyway to control the 4th place tolerance in the model. The config file is set correctly for the different decimal places. I can change the 1st, 2nd & 3rd place tolerance by doing a modification of those tolerances at the bottom of the screen. Where is this option control for the 4th place.
Thanks again for your help.
I am not able to change the linear linear_tol_0.0000 to the 3D until it is brought up in the 2D and then I have to add that parameter. Then you can do edit value and that will change the 3D part model. Is there a way to do this without having to cahnge the value in the 2D.
Can that be changed in the 3D part component outside changing it in the config.pro and the 2D, on older generated parts.
