casting corrosion allowance
What would be corrosion allowance  to calc wall thk of  volute casing (made from cast iron) ?
RE: casting corrosion allowance
Aleksandar,
API 610, the refinery pump standard, calls for the pressure containment case of a pump to be designed according to the rules of ASME Section VIII, the unfired pressure vessel code.  This implies that the corrosive and abrasive properties of the pumped fluid as well as the temperature and pressure be considered when establishing a corrosion allowance.  They then go further to recommend a minimum of 3mm corrosion allowance.
Gunnar Hole
