Membrane stress using shell elements.
I have been doing some work on pressure vessels using Ansys workbench 9.0 and classic Ansys 9.0.
Previously all the analyses I have done where generated from solid elements.
Part of the requirement is to Linearize the stress intensity. This was quite easy, as I simply transfered my analysis from Workbench to classic and then used the path operation command to get membrane or membrane + bending stresses.
Now however the model I am using is created from shell elements.
My question is how do I now get membrane and membrane + bending stresses since I cant now linearise.
Many thanks in advance
RE: Membrane stress using shell elements.
Cheers.
See FAQ569-1083 for details on how to make best use of Eng-Tips.com
