Gimballed joint
Gimballed joint
Gimballed joint
The following question has been 'bugging' me for a number of years. Can anyone answer it?
Is a Gimbaled joint a Hookes Joint alias (Universal Joint) (Cardan Joint), or is it a Constant Velocity Joint.
Thanks.
RE: Gimballed joint
i would guess Hook's
RE: Gimballed joint
Have you got a picture of one? If you mean one like on a compass binnacle on a boat, yes, it is Hookes joint.
Cheers
Greg Locock
RE: Gimballed joint
GregLocock.
Unfortunately, no picture. The rotorcraft industry has uses the expression 'gimbaled' on occasion, when referring to the motions of specific rotorhead designs. It has been used to refer to a Hooke's joint action and to a CVJ action.
The V-22 tiltrotor uses the term 'gimbaled' but I have been unable to discover if the proprotor and the engine remain in phase with each other as the joint flexes.
RE: Gimballed joint
Well, if it has one axle, it is a Hookes joint, if it doesn't, then it is probably a CV
Cheers
Greg Locock
