Axial Flow Compressor Efficiency
Can anyone provide some axial flow compressor efficiency calculations for a large frame gas turbine with multiple interstage cooling extractions
RE: Axial Flow Compressor Efficiency
You may want to check out: http://www.jsmatt.com/custom1.html
Jack D Mattinly is a co-author of Aircraft Engine Design and on this website their may be data available for you to use.
