API 650-installing a pressure transmitter directly in the roof
Can anyone please advise if installing a pressure transmitter directly in the roof of a refurbished API 650 tank is permissible? If it is, where can I find some installation details of this arrangement ?
Thanks.
RE: API 650-installing a pressure transmitter directly in the roof
I suggest that you refer to the requirements for mounting the specific piece of equip.  I'm sure their website will give diagrams.  I would expect that most times the unit would be mounted on a flanged or threaded roof nozzle.  API has standard details for roof nozzles also.
Steve Braune
Tank Industry Consultants
www.tankindustry.com
You can mount instrumentation in a tank roof in a threaded or flanged nozzle.  Normally a pressure transmitter would be located on the shell to measure liquid level, rather than on the roof.
