Pump Station Influent Deflection
The County I do work for is concerned about the influent sewer flow spilling directly onto the submersible pumps and their cables as well as directly onto the suction inlets for an above ground lift station. Does anyone have a recommended deflection product aside from installing a tee on the end of the influent pipe?
RE: Pump Station Influent Deflection
As for damage I have seen house brocks come down sewers and they can certainly damage cable and protective coatings.
You could hang a curtain of stainless steel chains. But agian they would have to be removable so that the pumps can be maintained.
