dimensioning thru VBA
I am trying to add a linear dimension to a drawing
and i am having trouble figuring out the parematers for adding a linear dimension
any examples would be much appricated..
RE: dimensioning thru VBA
Depending on which space you are in (model or layout) or in a block, you would add it too that object eg thisdrawing.modelspace.addDimAligned (extLine1Point, ExtLine2Point, TextPosition)
"Everybody is ignorant, only on different subjects." — Will Rogers
Thanks for the reply
I am in model space
I did get the dimensioning to work but how can i control where the dimension line will be ?
Is this the TextPosition ?
Guess I answered my own question...
textposition does control final location of text.
now another question
How can i use the dimension setting that are currently saved with the drawing ?
You will need to make the style you want current and then its creation is controlled by the style.
