measure distance to side of passing automobile at 100km/h
Problem:
Measurement of the distance to the side of an automobile,
(perpendicular to the direction of travel)
as it passes at 100km/h.
min. sample rate: 20 Hz
range: 1 to 10 meters
resolution: +/- 3 cm or better
output:analog 4-20mA
I have found the following:
1) ultrasonic sensors won't allow a high enough sample rate (due to speed of sound)
2) lasers will be affected by sunlight (test track has a north south orientation, laser will be pointing towards the sun part of the day)
3) microwave sensors may have too large a beam to accomplish the sample rate
Any ideas?
I still believe microwave is my best bet.
Mike Frank
frankm@mcmaster.ca
Any ideas?
Mike Frank
frankm@mcmaster.ca
RE: measure distance to side of passing automobile at 100km/h
Laser can be used. Just a question of wavelength, filtering and thresholding. BUT, commercial lasers with 1 kHz sampling are available with ~3 mm accuracy:
http://www
Your parameters indicate less than 0.2 s for total measurement period, so <4 shots at the PRF you've specified. At 1 kHz, you can get nearly 200 hits, to be used for range correlation/noise filtering.
TTFN
But if you end up back with ultrasonic, then you could have multiple pulses in the air at once to defeat the apparent transit time limit. To ensure that your return isn't swamped by an outgoing pulse, you can either ensure high T/R isolation, or cleverly vary the spacing on the outgoing pulses to allow the returns to sneak back in between at one point or another (requires full analysis to optimise the timing pattern). You might have to also code the pulses to distinguish which is which when there are two or three in the air at once.
Laser would be so much simpler. Police speed measuring laser systems work by measuring distances over time (not doppler shift as with police radar). They can be operated over relatively huge distances (as compared to 10m). Of course you code the IR laser ("AC") to futher distinguish it from sunlight ("DC").
Microwave should be quite simple over a 10m path (20m return). Use a swept microwave and the tone (frequency delta between what is being emitted now and then, then being after the return) can put the distance into the audio frequency domain where you can easily measure it. Watch out for sideways movement causing doppler.
3cm is fairly tight... You need to decide exactly where on the car you're measuring from. Most cars have more than 3cm of surface variation since they're not slab sided. Maybe you can install a corner reflector in one window?
The Speed of Light would be quite handy.
Yo would use your chirp to give you the round trip distance and the doppler can help with relative perpendicular velocity.
These are available from several manufacturers, especially the European ones, but the key is CW radar, not pulsed.
