measure distance to side of passing automobile at 100km/h
Problem:
Measurement of the distance to the side of an automobile,
(perpendicular to the direction of travel)
as it passes at 100km/h.
min. sample rate: 100 Hz
range: 1 to 10 meters
resolution: +/- 3 cm or better
output:analog 4-20mA
I have found the following:
1) ultrasonic sensors won't allow a high enough sample rate (due to speed of sound)
2) lasers will be affected by sunlight (test track has a north south orientation, laser will be pointing towards the sun part of the day)
3) microwave sensors may have too large a beam to accomplish the sample rate
Any ideas?
I still believe microwave is my best bet.
Mike Frank
frankm@mcmaster.ca
RE: measure distance to side of passing automobile at 100km/h
Please do not cross post.
Answered thread247-131744
TTFN
