I need a good definition of static pressure
Could anyone give me a good definition of static pressure
I need a good definition of static pressureI need a good definition of static pressure(OP)
Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesWhat is rapid injection molding? For engineers working with tight product design timelines, rapid injection molding can be a critical tool for prototyping and testing functional models. Download Now
The world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
RE: I need a good definition of static pressure
If you want to look at it in terms of a pitot tube in a pipe, the Dynamic pressure = (1/2)*density*velocity^2 (for an incompressible fluid). The total pressure is the pressure that would occur if the fluid were brough to rest in an reversible adiabatic (isentropic) process (=density*gravity*height of the liquid in the pitot tube as measured from center of inlet to top of liquid in the tube). As stated above, total pressure - dynamic pressure = static pressure.
hope this helps
Jproj
Pat http://www.aquasite.com/skonkworks
Total pressure (dynamic plus static) is read by a pitot tube pointing into the flow.
Static pressure is read by a pressure tap whose opening is perpendicular to the flow (a hole in the side of a pipe wall)
To make something clear here,
Static pressure is EQUAL to Total pressure if there is no velocity. If you check the air in your tires with a pressure gage, that is the static pressure.
When air is flowing through a pipe , there is both a STATIC component and a DYNAMIC component, as these other gentlemen have described. Measuring different ways will get you different components of that pressure. Certain types of pitot tubes are actually used to measure the speed of an airplane since it can eliminate the static component and use the dynamic component to calculate the airspeed.
Just a little more info to help...
