3D spline to represent wire
In Pro, I used to be able to create a curve between 2 points and then make it tangent to axes running through the points. I could then use this curve to make a 3D, swept feature to represent a wire or a pipe coming from a connector.
The 3D Sketch feature in SW looks like it could be used for the same purpose but I can't get the either end point to be tangent to an axis.
Can this be done?
SW 2005
Windows XP
SPO.0
PESOA
Can this be done?
SW 2005
Windows XP
SPO.0
PESOA
RE: 3D spline to represent wire
"I think there is a world market for maybe five computers."
Thomas Watson, chairman of IBM, 1943.
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
Hardie "Crashj" Johnson
Try adding a couple construction lines constrained collinear with the axes, and endpoints coincident or merged with the spline. Then constrain spline tangent to the construction lines.
PESOA
PESOA
Making the best use of this Forum. FAQ559-716
How to get answers to your SW questions. FAQ559-1091
Helpful SW websites every user should be aware of
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 4.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 1400
o
_`\(,_
(_)/ (_)
"There is no trouble so great or grave that cannot be much diminished by a nice cup of tea" Bernard-Paul Heroux
